Faceshop 8ez mac
connor61connor61 Posts: 0
Having trouble using faceshop as a plug-in. Just about finishes creating head/texture/morphs, then crashes. I am able to use faceshop on it's own and export ok. But, haven't had much experience with importing that kind of stuff. Faceshop is exporting 3 different file types: BMP, MTL and OBJ. Now, how do i import them and get them on my figure? Any help here would be much appreciated. Thanks.
  • connor61connor61 Posts: 0
    I can get the head to appear now. I'm guessing that's the OBJ file, but still can't get the texture / mat / face (MTL & BMP files) to import.
    I guess what i may need is just a quick run-through on using faceshop in conduction with adz.
  • StratDragonStratDragon Posts: 3,289
    an .MTL file is not an .MAT file, the .MTL is the file that is included with an .OBJ that includes the texture map info for the object, but not the actual texture images. An .OBJ does not need the .MTL in order to work but it assists the .OBJ with it's texture settings and the locations of the required images.
