How to convert any Genesis Clothings (G1,G2,G3 and G8) for Figures?
Hello,
 I know that this question was probably answered from somewhere in the forums, but I can't find it. So I was hoping does anyone knows how to convert the clothes from the genesis characters for the figures? For example, I had idea to make this character: Blue 2.0 (https://www.daz3d.com/blue-2-0) have it fit with the Genesis 3 Female suit (https://www.daz3d.com/holoflow-for-genesis-3-female-s) and the geneis 3 male pants. Please help if this can be done. Thank you so much
    edited May 2020
    Blue is NOT a Genesis character. It is a figure in its own right.
    One would have to made an autofit clone of Genesis 3 for Blue in order to make any of Genesis 3's clothing fit it. Not likely to be an easy task. One would have to match the shapes of Blue and Genesis 3, making 'clothing' of one figure [Blue's mesh as clothing on Genesis 3] in order to bring it back to its original mesh to make a morph. From this morph one makes the autofit clone.
    Post edited by Catherine3678ab on
  • 3Diva3Diva Posts: 12,058
    edited May 2020
    You might try Parenting Blue 2.0's head to the body of a Genesis figure (hiding all of Blue except his head and hiding the Genesis figure's head, eyes, ears, and mouth) and use some of the genesis morphs to approximate the look of the Blue 2.0 body. You could then, of course, use the Genesis clothing on the figure. It wouldn't be exactly Blue, but you might be able to get close if you have a good amount of morphs for your Genesis figure (or own a similar Alien, Goblin, or similarly shaped figure to start with).
    I did a test of that idea and it seems to work decently:
    I used HFS Ultimate Shapes, Genesis 8 Female Body Morphs, and of course Blue 2.0.
    If you have those and want the Scene Subset let me know and I can attach it.
    1000 x 1300 - 1M
    1000 x 1300 - 922K
    Post edited by 3Diva on
  • You might try Parenting Blue 2.0's head to the body of a Genesis figure (hiding all of Blue except his head and hiding the Genesis figure's head, eyes, ears, and mouth) and use some of the genesis morphs to approximate the look of the Blue 2.0 body. You could then, of course, use the Genesis clothing on the figure. It wouldn't be exactly Blue, but you might be able to get close if you have a good amount of morphs for your Genesis figure (or own a similar Alien, Goblin, or similarly shaped figure to start with).
    THAT'S IT!!! You are awesome!! I was thinking about doing that but I was hoping if can parent the body of the genesis 8 to Blue 2.0 would work. And it did work with a little help with the Mesh Grabber but unforunately the when I tried to move the arm and the leg the clothes just stay put. So I will do your way @Divamakeup and thank you for this great help!!! I really appreciate it.
    1280 x 1600 - 1M
    edited June 2020
    Ok, here's the scene subset if you want it: https://www.dropbox.com/s/0goxcehsyfifjrw/G8F with Blue 2 Head.zip?dl=0
    If you don't have some of the assets I used (like it might ask for Toon Generations Mats since I used that when setting up the skin) you'll probably get Missing File error messages when you load it - but you can ignore it. It shouldn't affect the overall look of the figure. As long as you have the morph packs I listed above it should end up looking similar to the above renders.
    If that doesn't work, let me know - I can send a regular scene file instead if that would work better.
  • Alright cool!! Thank you very much. You are so very kind and very helpful to me. I really appreciate it. Stay safe and take care. Thanks again.
