Dotify - does is work with hair and chlothing?
cherpenbeckcherpenbeck Posts: 1,418
Does anybody know if Dotify works with hair and clothing? Otherwise it will be of no use. Dots on the face, but not on the outfit - doesn't work.
«1
  • Silas3DSilas3D Posts: 836
    Hi Cherpenbeck, I designed the product for Genesis 8 Female figures rather than clothing, but given that it uses Iray decals and a geoshell it could be adapted to work with clothing - I'll post an example shortly!
    edited May 2020
    Here's a very quick before and after. All you need to do is:
    1. Apply Dotify to clothing
    2. Delete `Dotify - Decal Blocker` and `Dotify - Autohide Faces`
    3. Make any adjustments you wish to the decal surface settings eg color, metallicy etc - you could even load in your own seamless opacity map in the `Cutout` parameter
    4. Render
    The reason I didn't implement direct support for clothing in this product is that UV mapping tends to be consistent so you don't have the size issues between UV islands, so you can apply textures directly to clothing with minimal stretching, and there's already a lot of merchant resources, shader sets etc for that purpose. My vision was to create something unique that would allow you to apply a consistent texture to a figure without worrying about UV mapping.
    If there's enough demand for it then I may consider doing a clothing/hair addon :)
    1314 x 2136 - 2M
    1400 x 2234 - 2M
    Post edited by Silas3D on
    edited May 2020
    Here's an example with hair - a few more steps but doesn't take too long:
    1. Apply Dotify to hair
    2. Delete `Dotify - Autohide Faces`
    3. Select  `Dotify - Decal Blocker` (geoshell) and set the `Shell Node` in properties to your hair and turn off visibility for all surfaces but the scalp
    4. Apply base hair shader to your hair, then copy the scalp texture to the scalp surface in `Dotify - Decal Blocker`
    5. With the geometry editor tool, select the hair and turn off the scalp surface in the tool settings (this is to stop the decal from rendering for the scalp material - cutout opacity 0 has no effect)
    6. Make any adjustments you wish to the decal surface settings eg color
    7. Render
    1826 x 2504 - 3M
    1812 x 2492 - 3M
  • ArtiniArtini Posts: 10,943
    edited May 2020
    It looks interesting - I am always after NPR look.
    Will be nice, if you could produce something like Algovincian NPR style:
    https://www.daz3d.com/forums/discussion/324736/algovincian-non-photorealistic-rendering-npr-2019-2020#latest
    Maybe your next product... just an idea.
    Post edited by Artini on
    I'm familiar with Algovincian's extroadinary work - to attempt something like that would be literally years of work given the complex algorithms at play - so would unfortunately not be viable!
    Thanks for the honest answer.
    I am still hoping, that some brave Published Artist will take an effort and make something similar to Algovincians's NPR approach.
    Just want to clarify: could you post a render with Dotify applied to figure, clothes and hair at the same time.
    I hope, that it is possible.
    Yes I can do this shortly, but bear in mind this will be very subjective  - I purposely created the product in sunch a way that you could make your own presets after tweaking.
    edited May 2020
    Here's a very quick render - you can actually apply Dotify directly to the hair or clothing, you just won't be able to use the presets and will need to adjust scaling and other parameters manually.
    The only diffuse maps used in this product are for the eyes, brows and face lines, anything else you can recolor as you see fit! I included a light grey eye texture as well so that you can apply a color over the top to make your own.
    The second image is the same but with Girl 8 shape
    1878 x 2458 - 3M
    1748 x 2488 - 3M
    edited May 2020
    Double post
  • Drogo NazhurDrogo Nazhur Posts: 1,344
    edited May 2020
    I do digital comics using DAZ3d. I've always wanted to do a story where a comic book character comes to life but the post render work was prohibitive. Now it might be doable. When can we expect a male version?
    Post edited by Drogo Nazhur on
    My creative vision for this product was literally wanting to combine the comic book/pop art aesthetic with aspects of realism so it's good to know there is a demand for that!
    I mostly work with male characters myself and have often been frustrated with the lack of content in some areas - whilst I would like to do a male counterpart I need to see how the original product fares first, and it sounds like there is a demand for clothing/hair add ons so would probably come after that (and the product I'm currently working on).
  • cherpenbeckcherpenbeck Posts: 1,418
    Thanks for answering so fast, this makes your product a lot more usable.
    Pleasure! as mentioned in my previous comment it sounds like their is a demand for this shader system on clothing and hair, so I will seriously consider releasing an extra product that makes that easier without the manual steps.
  • jedijuddjedijudd Posts: 606
    Could that process be used for objects to?
    Well, I purchased the female version even though that is what I need the least. I'll be looking forward to the release of the other packages before I can begin my story.
  • dennisgray41dennisgray41 Posts: 938
    If you are trying to recreate the comic book coloring and shading it won't look right unless everything is done that way. Is there a post production method that could be applied to the whole scene?
    edited May 2020
    Generally what you say is true but I have a story in mind where comic strip characters come to life. So I would want ONLY that character (skin, hair & clothes) to have that comic book appearance. If I want the entire scene to have that apperance, that is easily done via other software after generating the image. ComicLife has it built in. So does MS-PowerPoint. Just to name a couple.
    Oh, that is interesting. Which option in MS PowerPoint gives that comic look?
    @jedijudd yes, you could apply this to any geometry with some manual tweaking as set out earlier in this thread.
    @drogonazhur thank you for the support!
    @dennisgray41 that wasn't my goal with this product - given that there's plenty of tools, photoshop filters and other software that help you achieve the overall comic effect. I wanted to give artists the flexibility to mix stylistic pop art and realistic PBR elements together in a unique product. Much like you could apply a realistic skin shader to a stylised figure like Aiko or The Girl.
    edited May 2020
    My first render with Dotify of Acicia - https://www.daz3d.com/acicia-bundle-for-genesis-8-females
    1000 x 1200 - 135K
    edited May 2020
    ... and with Dotify applied to most of the clothes. I skip applying Dotify to the hair - it seems too complicated, at the moment.
    1000 x 1200 - 170K
    edited May 2020
    How to use these scripts from Dotify?
    Does one apply them to the camera?
    436 x 310 - 56K
    edited May 2020
    1000 x 1200 - 420K
    Nice renders, @Artini!
    The readme included with the product tells you how the scripts work, but I'll tell you here as well - they will only work with Genesis 8 Female selected, as that's the primary use of the product - obviously the clothing and hair and other figures requires manual tweaking until a complementary product is created.
    • The `Camera - Close/Mid/Far` scripts change the Iray projection scale of the polka dot texture.
    • The `Camera - Sync Decal` is designed to prevent whats happening in your Underbelly render, by syncing the Iray projection rotations with the camera rotation.
    What I'd suggest is to load Genesis 8 Female in your scene and apply the presets/ scripts you want to her first, then reparent to Underbelly.
    In areas of high curvature you will still get a bit of stretching, but that can be minimised with small adjustments to the pose, camera rotation or the projection rotation settings.
    Thanks, Silas3D.
    So the camera scripts should be applied to the Genesis 8 Female character and not the dotify shell itself.
    Artini said:
    Thanks, Silas3D.
    Yes, all of the presets are applied when Genesis 8 Female is selected - I did this for convenience because of the multiple parts (decal, geoshell, autohide) it saves you having to select each part individually. Again this is all detailed in the readme so I would recommend taking a look at that when you have chance smiley
    edited June 2020
    Silas3D said:
    Artini said:
    Thanks, Silas3D.
    I could not find any documentation in the file downloaded from Daz 3D - IM00070079-01_DotifyforGenesis8Female.zip
    Even worse, Daz 3D Product Index - http://docs.daz3d.com/doku.php/public/read_me/index/start
    does not list product numbers greater than 69999, and your product got number 70079.
    What kind of documentation file are you refering to (.PDF)?
    There are no readme file at all in the product zip.
    My apologies @Artini, DAZ evidently haven't fully updated the Documentation Center yet. Here is the readme:
    http://docs.daz3d.com/doku.php/public/read_me/index/70079/start
    Ok, thanks for the link.
