Set Date, Time, Longitude & Latitude
I'm enjoying using the Render Settings for the Environmemt Mode using the Sun-Sky only in Daz Studio.
For each new scene I create I have to retype the date, time, Longitude & Latitude, which gets tedious.
Is there a way of saving these settings for any future scenes I create or do I have to keep enterin them in manually?
Currently the date for example always ddfault to 10.03.2015.
  • FishtalesFishtales Posts: 6,231
    Set up a scene using all your default settings, the ones you use the most with nothing else added, and save it as _default-scene. Then go to the menu Edit/Preferences/Scene click on the Load File option and brows to where you saved the _default-scene. If on Windows, when the explorer window opens right click on the icon and under properties choose Read Only and OK. Double click or select and it will load into Studio. Every time you load Studio that scene with all your default settings already set up will be loaded. It will also load if you use New to clear the render to start a new scene.
  • orandaoranda Posts: 22
    Thanks Fishtales - That worked a treat:-)
    You're welcome.
