OT - Zip Program for Mac?
Muon QuarkMuon Quark Posts: 596
edited May 2014 in The Commons
I'm having a hard time finding a good zip program for my mac. Anyone have a recommendation? Doesn't matter if it costs or if it's free. I'd like one where I can see the contents of the zip and then choose to add the contents to my runtime.
Thanks in advance.
Post edited by Muon Quark on
    The only one for Mac that I have heard of is Stuffit Expander (sit).
    There is a Windows version as well, but it was originally a Mac application. Smith Micro make it, it should be easy enough to find.
  • Alessandro MastronardiAlessandro Mastronardi Posts: 2,659
    Thanks in advance.
    I use Stuffit, but there is also Winzip for Mac, eventually. They are both good.
    I use The Unarchiver. It's available from the Mac app store, or here is the developer's site: http://unarchiver.c3.cx (Stuffit is on the app store too)
    When it comes to adding stuff to my runtimes, I use Folder Sync, again in the App store. or see http://www.destek.co.uk That also maintains my runtimes across two Macs.
  • Muon QuarkMuon Quark Posts: 596
    edited May 2014
    Thanks for the replies. I saw Winzip in the app store but it's like $30. It's getting stuff from the zip into the runtime folder that's a problem. Seems OSX will only give you the option to Replace content when trying to extract to a folder with the same name. Looks like Folder Sync might be an option. I don't understand why it's so hard to merge folders on a mac.
    Any other tips for getting files into the runtime? I'm looking at Folder Sync right now.
    EDIT to add: I currently have the Archiver.
  • estheresther Posts: 641
    semideiu's advanced library manager can install your zips where you want them in poser. But I just unzip the folder then I use an application called ditto to merge this into which ever runtime I want it merged into or I just attach it to poser as one of my 100s of external runtimes. That way i have all the mats for the thing with the thing. ie if it was an add on for a particular hair I would merge the add-on with the hair runtime, otherwise if it is just some outfit it has its own runtime. I use advanced library manager to search when i want something. e.g. I type in office and all my external runtime with the word office in the title instantly show up and then I can select the one or ones I want to look at.
    Love esther
  • wsterdanwsterdan Posts: 3,595
    There's also "BetterZip" for $19.99, which also allows you to merge the zip contents with the Runtime.
    -- Walt Sterdan
    Will check all those out, thanks. It's been a few years since I had a mac and I'm remembering the good with the bad. LOL
    Thanks.
  • GhostofMacbethGhostofMacbeth Posts: 1,774
    Most Macs in the recent memory come with Archive, it is a native zip and unzip compression utility.
  • greysgreys Posts: 335
    Seconding BetterZip (http://macitbetter.com/). It's cheaper from the developer's store than the Mac App store (at least, where I live).
    They also have a free Quick Look addon that lets you view the contents of zips by hitting space: http://macitbetter.com/BetterZip-Quick-Look-Generator/ The UI's a little outdated, but it works. :)
