Render turns out fine, actor is totally white
Hello,
Just like the title my render turns out fine, but my actor is white for some reason. I restarted my pc and reruning the same scene to be sure but any idea whats going on? This happens in a some parts of the scene, in others the actor renders out fine
  • Hello,
    It could be the environment settings, or the lights I think. I was having similar problem till i went into render settings>environment and tweaked up some settings like intensity etc..
  • It could be that the texture isn't applied.
  • SimonJMSimonJM Posts: 6,097
    What render engine are you using?
  • KINKYGR2014KINKYGR2014 Posts: 67
    Hey guys its in iray.  Really buffled by this. I am also using a skydome, if it makes any difference. Just trying to understand they why and how of this
    Skydomes are usually a 3Delight item as they have geometry and tend to block light, but as you can see the rendered image that's a (possible) problem for another day. If the figure is always white in the render then I'd suggest checking what shader(s) the figure uses as some of the custom shaders (such as AoA SSS) tend not to convert well for use by Iray.
  • odasteinodastein Posts: 606
    edited May 2020
    This happens from time to time, the solution usually suggested is to delete the content of the following folder :  C:\Users\AppData\Roaming\DAZ 3D\Studio4\Temp\Shaders\Brickyard     but normally just closing DAZ and restarting it fixes the problem. If it doesn't I try again until it does.
    Post edited by odastein on
