Transfer Utility Help
Hi,
I'm struggling with using the Transfer Utility tool on Daz Studio 4.12, Every time I use the tool this is the result, I'm trying to create an obj file, into clothing for the Genesis 2 female model.
https://ibb.co/qjGd7pV
If anyone has any suggestions, I would be really grateful.
Thank you.
1748 x 1748 - 605K
  • Richard HaseltineRichard Haseltine Posts: 112,003
    Is the clothing lining up, without any adjusting, with the figure before you run the Transfer Utility? Is the figure morphed?
  • mjpart98mjpart98 Posts: 2
    I've managed to fix the issue now, I was using a figure that was morphed. but after using the base model to create the clothing on its worked.
    Thank you!
