IDG dForce - Ponchos & Tabards Issue [SOLVED]
lithonZontalithonZonta Posts: 3
I'm having trouble applying a tabard to "The Brute 8":
https://www.daz3d.com/idg-dforce-ponchos-tabards
https://www.daz3d.com/the-brute-8
Other clothing loads correctly, the tabard claims to work with Genesis 8 Males - however it ends up piled on the floor at the model's feet.  It is also not parented to the model properly in the hierarchy.  When loading, it is not detected as compatible, so I get the "Fit To" dialog when loading.  "Genesis 8 Male" is not an available option when I go to choose what model this was designed for - and I can't figure out what kind of template would be closest (knee length dress?).
It is also unusual that the clothes are in the "Props->Wardrobe" section of Smart Content (where no other clothing is).
Phew!
Any help would be much appreciated - thanks!
Chad
Post edited by lithonZonta on
  • Richard HaseltineRichard Haseltine Posts: 111,371
    They are not meant to fit, you position them initially and they drape from there.
  • Ah!  I see: "Non-conforming."
    IDG dForce dynamics are designed to be simple, basic, non-conforming, rigged figures that can be used with any figure in your Library without conversion.
     Thank you!
  • How do I get the poncho onto the figure?
    It sits on the floor after being added, and is not parented, and when I run the simulation it goes low on the Y axis and cannot be moved.
    I have not had this issue with other dForce items.
