Substance Painter to Daz - Exporting and Setting up Textures
lilweeplilweep Posts: 2,873
I am having problems getting output from Substance Painter to look the same in Daz as it does in SP.
I have attached Daz Iray and Substance Painter Iray version.  As you can see, there is kind of a scarred/bumpy texture to the skin in Substance Painter Iray which I havent been able to show up in Daz Iray.
I exported the relevant textures Height and Normal maps from Substance Painter and plugged these into the Normal and Bump map in Daz Surfaces.
(Ignore my ugly texturing)
790 x 811 - 100K
1387 x 1206 - 240K
Post edited by lilweep on
  • lilweeplilweep Posts: 2,873
    Nevermind, i managed to get the scar-like texture to show up.  I am not sure what i did - i used a different export preset with 16bit normal map.
    But so many other factors changed, unsure which one made it successful.
    927 x 764 - 1M
  • SigurdSigurd Posts: 1,095
    Looks good!
  • Hi ! I have the same issue, on a dress texture, did you found a solution ?
