I want to make the I-ray emission surface invisible, but keep the light.
I want to make the I-ray emission surface invisible, but keep the light. I'm not talking about actual lights where you have the lovely render emitter option.  I am talking about the I-Ray emmisive surfaces you can ony control through the surfaces tab. So, basically, is there a command that does the same thing as Render Emiter does for lights.  If I reduce the opacity or visiblity options of the surface, the light goes with it. Is there some trick I'm not seeing? LOL Thanks.
  • FishtalesFishtales Posts: 6,232
    Change the Cutout option at the bottom of the surfaces tab to 0.0001.
  • ZuntarasZuntaras Posts: 17
    Switching the cutout opacity did the trick, thanks.  However, at the settings you sugessted the light stayed on but there was a swarm of fireflys leftover in the shape of the light emitter.  But its all good.  I just kept adding zeros to the setting and each time I did, more of the fireflys (white dots) dissapeared.  I finally ended up with a Cutout Opacity of  0.0000001 and the last of the dots vanished while the light stayed. Thank you. smiley
