Fury X Vehicle fails installation
I just purchased the Fury X vehicle and when I try to install it, the install fails. I tried the install update command and that failed. I then uninstalled it in DAZ Studio and then tried re-installing it and it failed. I then uninstalled it in Install Manger and then tried re-installing it. Still fails. Anyone else have this problem? Any ideas?
  • Richard HaseltineRichard Haseltine Posts: 110,867
    So you tried Connect (installing through Smart Content or the Install pane in DS), then with it uninstalled you tried Install Manager? What is the nature of the failure to install?
  • Mutant-XMutant-X Posts: 12
    I get the message "Fury X Install Failed" in the lower left corner of the DAZ screen.
    Here is output in the log file. It looks like a file is missing.
    2020-05-25 14:03:27.335 Beginning Install of "FuryX"
    2020-05-25 14:03:28.756 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Users/tomwi/OneDrive/Documents/DAZ 3D/Studio/My Daz Connect Library\data\cloud\1_64783\vehicles/vehicles/sareth/furyx/materials/furyx paint 01 ? kopia.duf.png.part"
    2020-05-25 14:04:16.398 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
    2020-05-25 14:06:13.750 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2020-05-25 14:07:04.078 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to open output file: "C:/Users/tomwi/OneDrive/Documents/DAZ 3D/Studio/My Daz Connect Library\data\cloud\1_64783\vehicles/vehicles/sareth/furyx/materials/furyx paint 01 ? kopia.duf.part"
    2020-05-25 14:07:04.470 "FuryX": Install Failed.
    2020-05-25 14:07:04.491 "FuryX": Install Failed.
    Here is another message I got:
    2020-05-25 14:27:18.879 C:/Users/tomwi/OneDrive/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_64783/vehicles/vehicles/sareth/furyx/furyx.duf (1,1): Syntax error - expected '{' or '['
    2020-05-25 14:27:18.883 Error reading file, see log for more details.
    I am thinking the files in the package are corrupt.
    That looks like the Connect install. What happens with an Install manager install, with the Connect uninstalled? What are you Install manager and Daz Studio content directories - are theya ctually pointing to the OneDrive location? Does your OneDrive have free space still? Do other installs work correctly?
    I uninstalled the Connect install and installed through the Install manager. Still doesn't work. OneDrive has free space. All other install worked fine.
    I don't have that product to check; since no one else appears to have any suggestions I think you ned to open a support ticket https://www.daz3d.com/help/help-contact-us
