Object that will take position of selected Node
How do you save a object that will take position of selected Node
How is this done, I only know it is possible because FM's FightClub Props do this very thing
For Instance if the Hand is selected, The prop will load directly on hand, or if HIp is selected Prop will load on hip and so on...
Post edited by TimingisEverything on
Nevermind, I guess All I had to do Was save a prop
though I have to drag it to the Node from the Scene window for it to work
it needs to be saved as a 'smart' prop. i forget how to do it in DS though.
ahh here's the thread :) http://www.daz3d.com/forums/discussion/1222/
To save as a Smart Prop is DAZ Studio 4.5+ you first parent the item to the Figure, remember for universal use you should use the base Genesis figure, you then select the item only in the Scene Tab and do a Save As> Figure/Prop Asset. The item that is saved will then be a smart prop and load to that same place on every load for the figure or shapes of that figure.
EDIT: It is also best for the Figure to be in the Default T pose for this but it is not needed. I just prefer that method.
