White dots with Stranded Whiskers
Hi, I bought the product Stranded Whiskers and get these white dots on the rendering. Can anyone tell me what I do wrong/what is wrong with the product? Thank you!
474 x 571 - 324K
474 x 571 - 470K
They're commonly referred to as "fireflies", and it's a computational error.
In some cases, saving and reloading will clear the issue.
In some cases, allowing a render to go longer may clear them, adjust the time and/or samples settings in Render settings tabs.
In some cases, you'll need to adjust the light settings, possibly adding a low intensity point or spot light in the areas.
In some cases, you'll need to adjust the shader settings.
In some cases, it's a computational error related to the interaction of the surfaces of one product and another, in this case it could be the hair and the skin.
So, try adjusting light, render, surface settings, to see if it clears.
Thank you!
