can i use growing up with Beck ?
AristocAristoc Posts: 254
edited May 2014 in New Users
http://www.daz3d.com/beck-for-m4
http://www.daz3d.com/growing-up-for-genesis-2-male-s-m6
I was wondering if I can u use Growing Up with the Beck for M4 character?
Thank you
Post edited by Aristoc on
  • AJ2112AJ2112 Posts: 1,417
    No, Growing up requires Genesis 2 / M6 Figures. Don't know if backward compatible.
  • Scott LivingstonScott Livingston Posts: 4,352
    edited May 2014
    The short answer is "No, they aren't compatible." The more detailed answer is "Yes, but it will require additional purchases and/or significant effort, and depending on how young you want the character to look, the results might be odd."
    Here are two options:
    1. Use the Beck textures on the Genesis figure, and use the Growing Up for Genesis product to make him younger. Beck's morphs are not compatible with Genesis, however, unless you use Genesis Generation X2 to convert them or do a manual conversion (Kattey has a thread describing this process).
    2. If you own "Michael 4 for Genesis 2 Male," then you can use the Beck textures on Genesis 2 Male, and use the Growing Up for Genesis 2 Male(s)" product to make him younger. Again, if you want to use Beck's morphs you will need to convert them. You could use Genesis Generation X2 plus the Genesis 2 add-on for that product to convert them.
    How young do you want to go? I don't own Beck, but it appears that all of his texture options have at least a little bit of stubble, which might look wrong if you want to create a young boy.
    Post edited by Scott Livingston on
