How do I import an object into Daz at high resolution
I'm trying to import an item of clothing I made in Marvelous Designer into Daz, but I notice there doesn't seem to be any option to change the resolution from base to high resolution. Looking at other items of clothing from both the Daz store and Renderosity, I notice that all the clothing is in high res. At what step, or what is the process for making the clothing item high res?
  • Richard HaseltineRichard Haseltine Posts: 111,666
    Edit>Figure>Geometry>Convert to SubD.
  • infinitetofuinfinitetofu Posts: 105
    Thank you!
    Another question. How do I prevent the clothing from moving and stretching unnaturally with the pose of the figure? Is that a JCM?
    909 x 473 - 44K
    In that case the mesh was closest to the tooes and so had their weights projected into it - you probably want to edit the weight maps (Node Weigh Map Brush tool) to zero the influence of the foot bones. You may then need to add oen or more JCMs to cope with extreme bends of the feet.
    Your help is always appreciated. I found this quick tutorial once you pointed me in the right direction.
    https://www.youtube.com/watch?v=CprimlL4BFo
