help! weird things happen! Daz3d
Hi,
So, since the new update of DAZ3d all seems to be broken....
After the update things started to fall apart and since my DB was a bit huge i descided to start fresh, delete everything, and install everything via DIM. Downloaded a freeby to make DIM files of the zips i had wich werent suitable for DIM.
Now, when i work on an animated project, i pose the head, mouth etc, and when i reload the saved file later on, the mouth perticulairly is not how i left it.
The dials seem to be the same tho, so after searching untill i allmost cried and kill myself, i descided to seek help here.
My log file is full of errors and all are a bit like this one:
2020-05-22 18:35:41.259 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6681): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLScream_HD.dsf#eCTRLScream?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Josephene%208/eJCMJosephene8_Scream_HDLv2.dsf#eJCMJosephene8_Scream_HDLv2
This expression is nowhere used.
Help would be appriciated, thanks.
Personally i suspect the way things are installed via DIM, but i compared the DIM file with the file wich isnt suited for DIM and it seems to be the same content.
Seems like it doesnt save all dials... got a morph called " open wide" and those settings dont all get saved in the save file
So i have the Head node, in the timeline is no keyframe when i reload the saved file, where it should have a keyframe. Why is it not saving all keyframes?
So i created a pose file for every frame of in this case the head... loaded the pose file on every frame, saved the file, reopened it, and gone are the moprhs... whats happening
https://www.daz3d.com/forums/discussion/408166/bug-report-animators-beware-ds-4-12-1-117-deletes-values-keyframes-en-masse
