HOW TO REMOVE TOTTALY DAZ3D?
thibautrobinthibautrobin Posts: 0
Hello i have a big problem using DAZ3D
i try to uninstal and erase every file i find in
Applications
shared
Library
but every time i believe its clean
and try to install it again
i have old setting inside and a lot of
function are there but with an exclamation mark
or i can not use any option.
Id like to reset my mac to make a clean new install
it's like i dont erase everything because every new install
make appear old option like victoria or wathever but it is empty no icon and a big "!"
how should i do?
Thank you for your help
  • TotteTotte Posts: 15,106
    What you have in inconsistency between the CMS (Content Management System) and the actual installed content.
    You can either uninstall the CMS (use the stop utility) before deleting it or delete it then reboot (as it will be running after you remove it and cause all kinds of weird errors. Then install it again with the cms installer that is located in the DIM application folder in /Applications/DAZ 3D.
  • thibautrobinthibautrobin Posts: 0
    Ok i will try to do it :)
    if i don't achieve i come back
    Thank you for your quick answer!!!
    It's awesome
    So now i have opened the activity monitor but didnt do anything
    and now im try to install again DAZ3D with the DAZ INSTALL MANAGER
    and ive got everything i have bought but there is not the DAZ3D application!!!
    It installs everything but no DAZ3D application...
    GOD help me!
    Did you uninstall with the install manager or not?
    And if it doesn't show up in new, does it show up under installed or do you have any filter suppressing it?
    Yes i did. But no problem i kept an older version of the software
    I installed it again but now the problem i still have is that
    313 x 273 - 31K
    Dont know how to fix it...
  • JaderailJaderail Posts: 0
    Do these two and then do a Content install and do Re-Import Metadata...
    298 x 269 - 31K
    Ok !!!! great!!! Seems to be near perfect.
    Its ok for what i need!!!!!!
    Thank you very much!!
