Connect an Object to a Polygon (Polygon Group Editor)
Is there any way to connect an object to a polygon.
So that the object will be moved togather with the polygon (if the father object of the polygon is morphing).
In Detail:
The "Polygon Group Editor" allows the selection of single polygons.
I want to create a Group from one polygon and want to add an object as a child.
But only the "Create Rigid Follow Node from Selected" creates a new "group".
Morphing the objects moves the childs as intended but to the wrong position.
Is there any other way.
Ok, i found the solution, after using "Create Rigid Follow Node from Selected" i have to move the Follow Node to the same position.
