figure suddenly turns white
SteveM17SteveM17 Posts: 1,061
Here's something that's happened to me a few times. I load a figure do a test render with some lights and so on, everything shows up as it should. I save the scene and reload it another day and when i render the figure (usually a genesis) renders completely white. If I re-add the textures it's fine, but what could cause this and how do i stop it? It doesn't happen all the time, just sometimes.
  • SimonJMSimonJM Posts: 6,102
    Taking a stab in the dark here, but it sounds liek a shader issue most often encountered with AoA shaders when using 3Delight render engine.  Somethign goes awry in the process resultign in a 'blank' texture.  If this is the case then a quick fix is usually to track down your Daz temporay directory F2 or Edit> Preferences under General tab) and delete the files in there - you should be able to get away with deleting just teh ones affected but much simpler just to do them all.
  • SteveM17SteveM17 Posts: 1,061
    Thanks, I'll look into that.
    Cheers.
