Adding Metadata to existing Freebie.
WilmapWilmap Posts: 2,917
I am in the process of adding Metadata to my freebies that are on ShareCG.
Which files, apart from adding the support files, do I need to replace please?
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    All of the metadata is contained in the 3 support files in the runtime/support folder.( well 2 and a thumbnail) :)
  • WilmapWilmap Posts: 2,917
    Thank you Razor, so all I need to do is add those to my original zip.
  • MBuschMBusch Posts: 547
    Assuming that you declared the root compatibilities and set compatibilities using the Content DB Editor, you just need include the 3 files saved in Runtime>Support. The metadata is in the .dsx file which can be opened in a text editor application. The .dsa and .jpg or .png are auxiliary files.
    Just for your reference I am attaching a link to the metadata which I just build for your last freebie:
    Gn2F Long Skirt & Top - SCG 75935
    I hope this help you. Oh... and thank you for the beautiful work shared with us.
    Thank you, but I get a 404 error when I try to download the file.
    Ops! Try again please: https://dl.dropboxusercontent.com/u/9581290/Gn2FLongSkirtTopSCG75935.zip
