How to pack jewelry/props?
emopie11emopie11 Posts: 0
edited May 2014 in New Users
Will work harder :)
Post edited by emopie11 on
  • frank0314frank0314 Posts: 15,101
    You may want to read through this info. http://docs.daz3d.com/doku.php/public/publishing/start
  • emopie11emopie11 Posts: 0
    I read that but didn't understand much.Can you help?
    edited May 2014
    Have a look at some of the jewelry in the store to get some idea of what would be acceptable.
    This one for example, if you check under what is included you can see what you would need tp provide
    http://www.daz3d.com/lady-edwina-jewels-for-any-figure
    Post edited by Chohole on
  • ann0314ann0314 Posts: 2,909
    Of possibly more use, DAZ also has a YouTube Channel (If you are packaging for use in DS etc) Granted DS has been updated since these videos but it should give you some idea of what you need to do.
    Their channel is here if you wanna take a peek: https://www.youtube.com/user/WWWDAZ3DCOM/featured
    I would also suggest searching YouTube for Creating Content for Genesis 2 or Genesis as there are a fair few other videos done by others out there that should also help :)
    If you want to make your item for Poser as well then I would look here on the basics (Though you would need to purchase Poser if you don't have it all ready): https://www.youtube.com/playlist?list=PLynyD-7entJ0exWVVKLZLvUYmMFLr6lOy and then additional search for Creating content in Poser for other videos or do a web search for either app. There is a fair bit of info out there so you should get a fairly good idea :)
    Hope that helps :)
    Thank you so much for the help and links .I am reading everything again.I have one more question though,which is easier creating content for poser or creating content for Daz3d?I went through a few things in the store and some jewelry were so beautiful.I guess with practice I will learn.Thanks again.
    That is a tough question to answer since it is more a matter of opinion. The workflows are different between the two apps so it would depend which one makes more sense to you rather than which is "easier". In general I would say DS may be easier to possibly learn the workflow of though Poser has a bit more tutorials etc you can find on the subject. So it's really a 50/50 split on which one would be easier for you. I would try them both in general or go with the app you have the most general experience with.
