removing all image maps in a scene with a couple of clicks???
Mistara
is it possible to remove all image maps in a scene with a couple of clicks?
i'm testing a theory twould be faster to keyframe and test timing with only a plain gray diffuse on everything, then load all the textures as the last thing.
would be interesting to see only the bump maps to see exactly what it's doing.
Post edited by Mistara on
You could try applying a shader base like the ubershader. If you don't select ignore that removes them all.
I just use the Genesis Default Thing. I saved it as a Shader for just such use. Then just Apply it to all Surfaces on a item with Multi Select in the Surfaces tab. The Default Genesis thing comes with the G2 stuff I think.
Good point Jaderail. Alternately you could save your own shader preset of it and uncheck the bump/displacement before you save if you want to leave those in place.
clever! Thanks!!! knew i was coming to right place for help. :)
