Is there an upgrade for Animate plus to Work in Studio 4?
Venator
Or will I have to purchase Animate 2?. I noticed a few glitches with the ani blocks when importing a scene from Studio 3.
There was never an upgrade path from (free) Animate Lite that comes with DAZ Studio.
I had the original version (Animate) I think, and got a slight reduction for upgrading to Animate 2, but I also bought it when it was on sale, so that helped a lot :)
I see it is on sale at the moment, it sometimes goes to 50% off, but that would usually only be once or twice a year I think.
I have AniMate Plus, I moved up to AniMate2 as soon as I could afford it. I do not remember any errors before I upgraded. What are you seeing that you where not seeing before?
JimmyC Thanks for your reply. Animate plus wasn't free but it's nice to know that you can get Animate 2 at reduced rates. I'll keep my eyes peeled. :)
Jaderail Thanks for your reply. Some of the blocks act weird especially when one block joins over to another. The arms and or legs twist out of proportion yet in studio 3 they are fine. When using the free Dynamic clothes software in conjunction with animate the figure freezes during the draping process.
Hmm... Which figures are you using in AniMate Plus and If I may ask which AniBlocks cause the error?
I have a rather large Collection of AniBlocks, if you can tell me the Set name and Block that errors I'll check the settings and see if I can figure out a work around for you.
Speaking of Animate2, I am keyframing a "slime-cycle" for the Slimebeast at the moment. I find it easiest to manually enter param values,each affected node, on pivotol key-frames and then clean up interpolation mistakes afterwards. However Animating in Poser and Carrara with a Graph curve editor is preferred.
I have Graphmate, but have never been able to get the Graph module to fully work with DAZ, have either of you had success with it? My plugin installs and serial activated but Its display only shows keyframes but no node parameter levels. I get a vertical line (keyframe data), no horizontal levels (param data) when I select an isolated node. I wish there was a user manual for it and I have not picked up what I am missing in the few tutorial vids out there.
Thanks Jaderail. I'm using Victoria 4 Ultimate and Sk Amotions Catwalk blocks. The problem occurs after the 180 degree turn block.
Thanks for all the responses on this one but I think I've solved it. I was using the time line as opposed to the animate lite control and that seems to have been where the problem arose. Working fine now though. :)
EDIT @ Pebbly glad you worked it out.
Thanks Jaderail,
The circled area is the keyframe indicator that does track animation - however no values appear to graph. Note the keyframe carots indicator in timeline showing rotational values for the node exist.
I had to sleep but here you go... SEE Image Below.
And this is the best short TUT on both GraphMate and KeyMate...
http://www.youtube.com/watch?v=ryUgvapGUG0
Please Note I keep my GraphMate on the Left Dock and Parameters on my Right. (Not Shown Above as I wanted to show it Centered) That allows me fast access to all Nodes as I select from the Scene Tab. You may wish to edit your layout for your own work flow. I did.
EDIT: I have thought of making a Room TAB in DAZ just for GraphMate, KeyMate , Parameters and the Timeline. That would give much more room to work in. I will do so Soon I think.
