Converting Poser Poses to Use in DAZ Studio
Is there any means to convert poses meant for use in Poser to a format compatible with DAZ Studio 4.12? Thanks very much.
  • fixmypcmikefixmypcmike Posts: 19,729
    DS already reads Poser-format .pz2 files.
  • contedesfeescontedesfees Posts: 299
    Well, yes it does. But I suspect they cannot be applied to Genesis figures of any generation. That is what I was thinking of. I acknowledge that I could have phrased it more effectively. Can Poser poses be converted for use with Genesis figures? And thanks again, Fixmypcmike, good of you to reply.
    They can be, although of course poses for the newer figures aren't normally in that format, so they'll need adjustment.  V4 poses applied to Genesis 1 are pretty easy to adjust, for example.  If you have a pose converter that only works on .duf files, that's a different matter.  You would need to apply the pose to its intended figure and save it as a pose preset,  There are probably products to batch convert those.
    Thanks Fixmypcmike, I appreciate it. Time to get to work and see what happens when you give it a whirl.
