V4 hair on G2F
rumpotrumpot Posts: 96
Does it work? In particular most Valea hair is for V4 ( moon shadow or forest princess ) will they work on G2F, pretty good sale right now.
Regards
  • FSMCDesignsFSMCDesigns Posts: 12,858
    Most hair works on any figure. If it is long hair, just don't use autofit. make sure the figure is in the default pose/position, load the hair, cancel autofit and then just parent it to the head. If you need a more precise fit, enable a smoothing modifier with GF2 as the collision object and viola.
  • rumpotrumpot Posts: 96
    Thanks for the tip, it is long hair so I'll try the not use auto fit as you suggest.
    Regards
