BUG REPORT Wireframe Mode crashes new public build
jpetersen1jpetersen1 Posts: 148
edited June 2020 in Daz Studio Discussion
V 4.12.2 BETA - if you go into the simple Wireframe or shaded Wireframe mode in the Viewport, as soon as you try to move any asset in the scene, it crashes. It does so every time. Impossible to use it.
  • jpetersen1jpetersen1 Posts: 148
    edited May 2020
    I should also mention that the same version v4.12.2 crashes when you try to save the scene (this didn't usually happen with the previous version).
    It crashes about 30% of the time (when saving a scene). Then, of course, you lose the most recent changes.
    I'm not certain yet, I'll have to experiment, but it's possible that rendering first and then immediately saving the scene (before making changes) might prevent the crash, but I only just noticed this so I haven't tested it to see if it happens every time.
    Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 112,037
    Please note that a forum post is not a bug report - it's a good way to get feedback and refine the description of an issue, but actual reprots are made via a support ticket https://www.daz3d.com/help/help-contact-us
    I just loaded a scene and put it in wireframe preview mode, no problem movign or posing - what  are your system specifications, and if you have multiple GPUs (one on the CPU and one or more AMD/nVidia stand-alone) which is DS using?
    I haven't saved a lot of files from the ebta, but some and they did not cause a crash.
    Belateedly moved to Daz Studio Discussion as it was not a Product Suggestion.
