Video Tutorial - How To undress Pants
LoonyLoony Posts: 1,817
edited May 2020 in Freebies
Here is a Video Tutorial, which I made for this Thread:
https://www.daz3d.com/forums/discussion/407611/pulling-up-jeans
↓Video, click it.
I hope that help beginners!
You need for this ManFriday's Mesh Grabber: https://www.daz3d.com/mesh-grabber
Post edited by Loony on
  • bnstone_stonebnstone_stone Posts: 110
    Mesh Grabber with rotation highly recommended.
  • LoonyLoony Posts: 1,817
    Well... I MADE a Tutorial WITH Meshgrabber ;).... so maybe you thought I asked here, but I did TEACHED here, how to make it ;)
    Thank you for mentioning this, added to that ever growing wish list ;-)
    https://www.daz3d.com/mesh-grabber-rotations-add-on
  • richardandtracyrichardandtracy Posts: 8,236
    edited June 2020
    An alternative method I got to work uses dForce.
    1. Stand figure in A or T pose and not constricting the trousers in any way.
    2. Apply dForce dynamic fabric to trousers.
    3. Set friction to zero in all trouser material zones.
    4. Set stretch stiffness very low, 0.05 or less for all material zones.
    5. Set expansion/contraction ratio at 110% to make a bit baggy and rumpled if the fabric stretches.
    6. Set gravity to a high figure in the simulation tab. I ended up with 3 after starting at 10.
    7. Use single frame simulation.
    8. Switch 'Start from memorised pose' to off in simulation tab.
    9. Save file in case of explosion.
    10. Run simulation with mouse hovering over 'cancel' button to stop simulation when at an appropriate point. If the trousers move too fast to stop at a sensible point, reduce gravity a bit. It will need to be moderately high to stretch the trousers over the buttocks, which is why I started at Gravity=10 and such a low stretch stiffness.
    11. Once happy with the position, prevent further trouser simulation, and pose figure.
    This seemed to work fairly well - much better than I expected especially as I was using Genesis 2 trousers on G8F. Can be seen in this NSFW image: https://www.renderosity.com/mod/gallery/de-bagging-a-friend-/2948423/
    Post edited by richardandtracy on
  • MilosGulanMilosGulan Posts: 1,993
    Thanks for info, that looks like very useful addon :) wishlisted it yes
