Hidden folder in my DAZ library
backgroundbackground Posts: 941
edited May 2020 in The Commons
Hi,
I've noticed that if I have hidden folders in my DAZ library, specifically in the morphs area, then the morphs inside those folders don't appear in DAZ. Is this deliberate?
Post edited by background on
  • fixmypcmikefixmypcmike Posts: 19,735
    What exact path and how are you hiding them?
  • backgroundbackground Posts: 941
    edited May 2020
    They were folders inside the data folder, 'My DAZ 3D Library\data\DAZ 3D\genesis 3\female\morphs\foldername'  If I hide a folder in Windows explorer such as zev0, then none of the zev0 morphs appear when i load genesis 3 female. It's not a problem as i have unhidden the relevant folders now, i was just suprised that DAZ seemed to be acting on the Windows folder properties setting 'hidden'. I think the got like this becasue I used a file recovery program to extract some files from a faulty drive.
    What prompted me to look at the folders was  I was getting warning messages in the log like "Could not find output property for formula: Genesis3Female:/data/DAZ%203D/Genesis%203/Female/Morphs  etc etc"
    Once the folder ( for example zev0)  was hidden even reinstalling the morphs via DIM didn't fix them, presumablly because DIM doesn't worry about the folder settings.where it puts the files.
  • PlantPlant Posts: 127
    Just 2 say they are not hiden in mine. did you try deleting them before installing + redownload the files
    Hi, no they got hidden when I used a program to restore some file off a faulty drive. I had some folders on that old drive containing morphs I made myself a while back, and i restored probably too may folders. I din't try deleting the files , but I did re-download and overwrote the morph files that weren't working, however this didn't fix the problem. The problem was the folders i restored had got set to hidden. I set all the folderers to unhidden and now everything is working again.  Before I worked out about the hidden folders I was worried I might need to reinstall Studio, since nothing I did would make those morphs visible, but as I say, it's all fine now.
    Thanks
