Is there a way to "flip" the horizontal orientation of a dome?
An environment map I'm using has rocks on the left and the ocean to the right. I'd like to swap the orientation so it's a mirror image, and the ocean is the left, and the rocks are to the right. Is there a way to do this?
Thanks! These forums are so helpful. :)
  • docbotherdocbother Posts: 108
    Maybe scale it by a negative 100 percent along the X axis or Z axis.
  • alan bard newcomeralan bard newcomer Posts: 2,426
    edited May 2020
    photoshop will open and save HDR files ...
    click on the hdr icon in the render tab and hit browse and you'll be in the folder with the hdr
    In PC you can now click on the hdr and say open with photoshop ..  |
    use the flip horizontal command
    save the hdr was xxxflip
    then when you close the photoshop window
    you'll still be where you browsed from daz.. select the new one you made and hit the enter key in that window and you'll have your reversed image where the other one was
    I don't know if gimp does hdr
    but any program that can open that format will work
    for what's it's worth you can use this same method to modify textures in daz also ..
    the background in this picture was a nice sunny blue sky hdr and I did exactly what I listed above except instead of flipping the image side to side
    I inverted the color profile and maybe tweaked the result a little saved it and choose it instead of the blue sky one for the render.
    2000 x 1000 - 971K
    Post edited by alan bard newcomer on
