Dior HD & Nightmare Fuel
evacynevacyn Posts: 993
edited May 2020 in The Commons
So, I decided to check out Mousso's Dior HD (https://www.daz3d.com/dior-hd-for-genesis-8-female) I bought some weeks back and noticed that when I posed her, she turned into this horrible mess. I thought a re-install would fix it, but no luck. Then I re-installed the Genesis 8 Essentials to see if something was corrupted, but no luck again. Then I decided to see if I could dial her morphs into a base G8F and noticed that if I just used her 'Head' and 'Body' morphs, all was good. But if I used her entire character morph, it made her the stuff of nightmares.
Quick question to someone who has her - Can you please test out to see if this is just on my end? If not, I'll submit a ticket. Otherwise, I'd love to know if there's something corrupt on my end. Thanks!
Edited to fix image.
Post edited by evacyn on
  • davidtriunedavidtriune Posts: 452
    looks fine on my end.
    did you turning off all your hidden morphs to see if they had something to do with it?
    1246 x 945 - 130K
  • KamaroticaKamarotica Posts: 73
    That is likely on your end. I have done quite a few renders with Dior and she works fine for me.
  • evacynevacyn Posts: 993
    Okay - thank you both. I'll check to see if there are some hidden morphs causing the issue.
  • BartlebyBartleby Posts: 58
    I had a very similar effect with a different character that turned out to be caused by parenting the character to another object and changing that objects scale.
