[Solved] Shaders suddenly broken
Hey everybody,
I've been using DAZ for a while now and today I opened it up like any other time but suddenly, upon loading a genesis 3 figure, it just appears gray. The shaders tab only shows General/Lines/UV Maps/Smoothing.
I then added hair and loaded a preset iray shader onto it, which seems to work fine in the viewport but when rendered it just appears completely gray with no opacity. However, other hairstyles using iray seem to still work fine.
Then I also added a piece of clothing using an iray shader and it worked fine. After a few more tests every piece of clothing worked like it did yesterday, only the one hairstyle seems to have problems as well as all 3delight shaders.
I hope someone on here knows what it could be because I didn't change anything and it worked fine just a day ago :(
Okay, for some reason restarting the pc fixed every problem. Never had this happen before, but I'm happy everything is back to normal
