EuropApt Lamp without Structure
LoonyLoony Posts: 1,817
Hi,
I have this appartment:
https://www.daz3d.com/european-style-apartment
And I wanna use that Lamp at the roof (which there have also no light):
But it is empty inside:
And well, the emission make nothing :(
Interesting is, it HAVE a emission map:
And yes I did turned the mission off there, cuz it doesnt work.
I made the emission now on the glass:
I use Watt for the inside, but... it doesnt look as good as it should.
Any idea what I can do? Also... it have 2 surfaces with 44polygons in the geoeditor but both are not there.
No bulb no emission.
Post edited by Loony on
  • SimonJMSimonJM Posts: 6,097
    Yes, there look to be two material zones with emission set, but there also seems to be no geometry/mesh associated with them, even ramping Luminance into 7 digits had no effect!  I copy/pasted LampEmis surfaces settinsg to PNTR_GlassTranslucent and that seems to, at least, be a lot better, and is very much akin to your approach.
  • LoonyLoony Posts: 1,817
    edited May 2020
    I used now a bulb from a other lamp, did delete everything around and did moved it in.
    I reduced the cutout a little bit.
    I build now the Floorway to make a walk from room 1 to room 2 and that room have the other Bulb which have a Light Promo picture.
    its the same Lamp.
    but:
    it have Emission settings AND a own Surface already, but... there is no object.
    But even with emission on is it not very bright.
    So I have to readjust it by myself, its a bit sad, that the Lamp get not correct adjusted for the Preload Set :/
  • RD2ARTRD2ART Posts: 28
    I am not sure, if I am answering your question,  but each light has an on and off morph inside the parameters tab. You can control the light that way. I have used both the kitchen and the above lamp in other products to light rooms that have poor lighting. Let me know if this helps.
    Oh.... really xD... I mean... I never! Looked in the parameters, I am in the workflow to look instant in the surface to check the emission :D
    Man I feel stupid :(
    I didnt thinked about to check the parameters, but I will do that! ( I am in a Long time render atm QHD).
