Draping clothing
Hi all,
Apologies if this is the wrong sub-forum. But it is a kind of nuts and bolts question, so...
I have been working on a render which is meant to be suggestive, a bed with piled sheets and suggestive shadows hitting the wall behind the lamp. To get the point across, I want to show some discarded clothing, some on the floor, maybe draped across the bed post. Is there a way to do this with the dynamic cloth draping options, or am I barking up the wrong tree. I just can't work out how to do it. Is it possible? Can someone give me instructions as to how I would go about it?
Thanks in advance...
    If you are using DAZ Studio, dynamic cloth only works on items made for the system -- you can't just drape any item.
  • edited December 1969
    Thanks, I figured that was probably the case. Shame :-/
  • atticanneatticanne Posts: 3,009
    I've never used Dynamic Clothing, but could it be draped on a figure, then hide the figure?
    Not really, I want the items to be strewn on the floor in as pile, draped over a bedpost etc. Dynamic clothing worn by a figure just tries to dangle it on the figure itself.
    (or so I understand, I've never really worked out how to get it looking nice that way either)
    You can do that with dynamic clothing, it doesn't have to be put on a figure.
    Here's a quick example:
    1023 x 795 - 283K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,600
    edited April 2014
    check the Optitex freebies, would not matter which figure
    That's awesome, it's exactly what I'm after.
    Sorry to be thick, but can you tell me how to do it (or point me to a tutorial). I just can't work it out, never seems to work for me...
    I just took a dynamic item (the Monster Robe), rotated it 90 degrees and raised it above the chair, and let it drape.
  • FirstBastionFirstBastion Posts: 8,076
    This optitex bundle of clothes has plenty of variety for a clothing pile on the floor, http://www.daz3d.com/ultimate-pattern-design-kit
    As Wendy mentioned the Optitex site has clothing freebies too
