Stains on clothing objects caused by smoothing modifier
jdavison67jdavison67 Posts: 690
edited May 2020 in The Commons
I've noticed this a lot more recetly in DAZ.
If I use a smoothing modifier to eliminate poke through, that areas texture gets a visible darker line around it...
I tried using a push modifier, and it's even worse...
Is this to be expected from now on ?
JD
574 x 347 - 400K
Post edited by jdavison67 on
  • jmtbankjmtbank Posts: 189
    edited May 2020
    Something's clipping with it. Usually geoshells.
    Post edited by jmtbank on
  • jdavison67jdavison67 Posts: 690
    Yeah, but I dont have any geoshells loaded...
    I was able to get it to go away by removing both the push modifier and smoothing modifier, then I used the grab tool.
    It's just a pain...
    I find I wind up having to do multiple renders, to spot fix things like this more often, these days...
    JD
