Titan RTX
Hello fellow artists and developers, i have a question for you. Does Daz Studio support NVlink? How about when you have 2 x Titan RTX would that count as 48 gb vram and double the cuda cores? Thank you.
  • LeanaLeana Posts: 13,508
    Since version 4.12.1 DS supports memory pooling via nvlink 2.0 on compatible cards, including Titan RTX. It won't be the same as having 48GB on one card as the system has to use VRAM on both, and the memory pooling is only for textures for now so geometry data will be loaded on both cards.
    No idea about Cuda cores
  • kenshaw011267kenshaw011267 Posts: 3,805
    You get the CUDA on both cards. You get that whether NVLink works or not. That's the argument for 2 Titans versus the RTX Quadro 8000 which has 48Gb of VRAM natively but only has the same amount of CUDA, roughly, as the Titan and 2 Titans cost about one 8000 does.
