PC freezes when attempting to simulate(Dforce)
Eeyore
This problem might have been covered elsewhere, but I haven't found it anywhere. The problem I'm having is that when I attempt to simulate anything my pc seems to just go into a complete standstill. Absolutely nothing happens w/the exception of the appropriate dialog box for the simulation popping up. The time and everything freezes at 1 sec. If you click on anything you see the "(Not Responding)" tag, and anything else will then cause the screen to go into semitransparent white, and still nothing else happens.
I have checked all I know to look at, all items at default settings, Open CL Device setting is: Open CL Intel UHD 630.
My laptop, Alienware 17R5, i7-8750H CPU, 16GB RAM, NVIDIA GTX1070, running Windows 10, and all drivers updated,
It also doesn't matter if I try to simulate from a a set pose or from the timeline. I get no other error messages as I have to end the program.
I also am not attempting to simulate big items or multiples, one G8F character, non-Dforce hair, and just a simple Dforce dress.
Is there something I'm missing, need to load(reload).... I'm not highly knowledged about indepth software issues, so please, keep is simple.
I really appreciate any help that can be offered as I'd love to be able to utilize Dforce. Thanks!
With a 1070 you should be using the GPU for the Open CL Device.
I will give it a shot and see what happens. Thanks.
Wow. That did the trick. Simulated and rendered in just a couple minutes. Again, thank you.
