need more Vanguard containers*SOLVED*
IkyotoIkyoto Posts: 1,159
i can select the "container" part, but i need to save it as a separate prop so i can add more of them. daz studio 4.6.2.118
Post edited by Ikyoto on
  • JaderailJaderail Posts: 0
    Hmm.. I do not have the Vanguard but From the Promo Images it appears doable. If the Container is Grouped to the Ship in the Scene Tab do a Right click and see if Un-Parent is a option. If it is that will do what you need. Un-Parent and then you could just create instances or save out as a single loadable prop either one.
  • Richard HaseltineRichard Haseltine Posts: 111,984
    The container is a bone, not a prop. What you could do is select all, deselect the container, use the Parameters pane to turn off visibility for the selected items; then export as OBJ, reimport and copy the materials across.
  • IkyotoIkyoto Posts: 1,159
    GOT IT!
    select all the bones in the scene and turn the visibility "off". it the are some left in the view, you can right click on them and turn off the visibility. Then select the part you want, and export s"OBJ"
    new scene, import and you've got it!
    git my cargo AND seating- thanks kids!
    Richard the man. I now want to go Buy the Vanguard. But do I need it? No, do I want it? Yes.
    edited May 2014
    it's my "go to" for sci-fi. just wish there was a larger ship (big cargo hauler type) in the same style so i didn't have to kit bash so much. seriously cool ship
