Morph limits?
BurpeeBurpee Posts: 155
I added all my morphs to my figure and in settings I set -1 min and 1 max but when I test the dials they don't stop at 1 or -1. Easy way to make this behave?
Also, when I make props I use Object Extractor to remove the object information from the pp2 file. Do CR2s have the same need or is this just a prop thing?
  • Cayman StudiosCayman Studios Posts: 1,145
    You have to make sure the "Use Limits" box is ticked.
  • DZ_jaredDZ_jared Posts: 1,316
    Here's a screen shot.
    545 x 414 - 34K
  • BejaymacBejaymac Posts: 2,015
    edited April 2014
    I get the feeling this thread is probably in the wrong forum, as the DS PP2 exporter script doesn't embed the mesh in the PP2, it creates a separate OBJ (unless it's been updated recently), and to answer your question, yes it's usually just a "prop thing", but you can find embedded mesh in a CR2, but it's usually because a prop was parented to a figure when the figure was saved back to the figure library.
    Post edited by Bejaymac on
