Feature Request: Make 'Visible In Viewport' able to be keyed
When animating, sometimes I will swap out figures during an animation, which I can do easily mid-render by keyframing 'visible in render' but the model still sticks around in viewport which can cause a mess. I would ask that in the next revision that 'visible in viewport' becomes a variable that can be keyed same as visible in render is able to be keyed.
  • chris-2599934chris-2599934 Posts: 1,975
    Can you key the "visible" property instead? (I know zero about animation) If they're not visible in the render or the viewport, what's left?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,498
    I didn't even know you could key that in DAZ studio without Casual's script, interesting
    while setting up why not just hide whichever one you want in the viewport, once its rendering what happens in the viewport which isn't a lot, is irrelevant
