Material specific light source?
I want to know if there's a way to setup a light that only affects a certain material. For instance I have material A & B, and lightsource 1 & 2. I want to make light 1 affect material A only, and I want light 2 to affect meterial B only.
Is there a way to make light 1 cast shadows on material A alone? Conversely, is there a way to make material A be affected by light 1 alone?
    It's pretty easy to set up in 3Delight. For IRay, sorry can't help, could be tricky to do in one render pass.
  • Faux2DFaux2D Posts: 464
    Excellent. I'm actually only interested in 3Delight. What's the secret?
    https://www.daz3d.com/advanced-daz-studio-light-bundle
    If you don't have them, get them:) You load a spot or distant light and flag it to only see surfaces with a certain diffuse- or ambient strength. This is done in the parameters pane/light/advanced options or something like that. Busy rendering so can't check atm. Example: You have two characters in the scene, and two AoA spotlights. Set all surfaces of one characters to 100% diffuse strength, and all surfaces of the other to 99% diffuse strength. Now flag one spot to illuminate only surfaces with 100% diffuse strength and the other to illuminate those with 99%  diffuse strength.
    You can use the ambient channel if you prefer that. Like using 1% ambient strength on one of the characters, and flag the light accordingly.
    If you don't have these lights, things will get a little bit more complicated, but it can still be done using light categories or trace groups.
