"Ranger Hair"
Leo ChenLeo Chen Posts: 697
edited April 2014 in New Users
The hair has penetrated the left hand.
Is there anyway to adjust the hair to avoid the problem?
1370 x 820 - 469K
1315 x 1920 - 410K
Post edited by Leo Chen on
  • TotteTotte Posts: 15,312
    You can use a DForm on the hair to push it away.
  • Leo ChenLeo Chen Posts: 697
    Thank you,Totte.
    I still don't know anything about "De-form" tool... :red:
    May I ask? Where I can start with?
    Yes thats it!
    Totte said:
    Yes thats it!
    Thank you very much.
    I will try to learn it harder......
    Something strange happens!
    The yellow mesh does not appear!
    How come?
    PS: As first image.
    It is the scene I am going to D-form.
    The second image is normal.
    1246 x 519 - 268K
    1114 x 761 - 393K
    edited April 2014
    when you apply D-former after pozing Actor, D-former field keep zero positon.
    it cause many difficulity to adjust the influence.
    please save your scene to re-produce easy,,
    then
    1. memorize figure poze. (select your Actor) (from top menu>edit>figure )
    2. delete current D-fomer base and field from hair.
    3 set zero figure poze. (Actor)
    4 apply D-former again. (select Hair)
    5 restore figure poze (select your Actor)
    Though the influenced field should be different positon, but you may find it ,then adjust the filed positon.
    Then,, now you can color and adjust d-former weight as you like (By node weight map tool) too.
    648 x 628 - 51K
    Post edited by kitakoredaz on
    Thank you,kitakoredaz.
    You are right.
    I zero the figure's pose then the d-form back to normal.
