Clothes won't fit to model
I used the super suit for Genesis 2 male and Michael 6. I've tried putting it on Genesis 2 several times, and even bought Michael 6 just to see if it would fit better. The suit looks marbled with flesh on black because it isn't covering the skin all over. I've tried adjusting all the settings I can think of, making the body smaller, thinner, etc. Nothing is working so far. Does anyone have any advice? Also I'm on a Mac, if that makes a difference, since the settings on mine are different than the ones on my friend's, who has a PC. Very new to this.
2688 x 1462 - 339K
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Have you tried rendering, in case it's just a preview issue?
    I believe that is just the way the suit is, I think it was due to the way it used displacement.
  • CdpiersonCdpierson Posts: 75
    The same thing happens with the super suit for Genesis 2 Females.  Except for small areas on the inner thighs and crotch, the only thing I've found that fixes it is Fit Control.  It seems to fill in the poke through without making the suit larger.  The areas it doesn't fix I hide with the pose or fill them in post render.
  • Thank you
    Thank you, I'll try that!
  • Have you tried rendering, in case it's just a preview issue?
    I tried this and rendered, and it mostly fixed itself, but not completely. In the end I was able to hide the parts that didn't fix for the final product. Still working on it though.
