ISO changes during renders.
jd641jd641 Posts: 463
edited May 2020 in The Commons
Sometimes I can change my ISO settings while rendering and see the bightness changes and my render continues without issue. Sometimes I change the ISO and my render goes back to interation 1 and starts all over again.I just had a 12 hour render start over because I changed my ISO settings from 200 to 400 but last night at two hours into the render I changed it several times and it kept going.
So what's the logic behind this and why would it work earlier in the render but not when I acutally needed it to work? :(
(using 4.12.1.117)
Post edited by jd641 on
    Never knew that was even an option except in iray preview mode, very surprising since I wouldn't even think that would work during an actual render.
  • Silent WinterSilent Winter Posts: 3,955
    It doesn't really go back to 0% - the progress bar shows that but keep going and you'll notice it shoot up a lot faster to 'catch up' to where it was before.
    And @FSMCDesigns - there's a little button on the middle-left of the render window that opens up some of the render controls. Not all, but you can change certain things mid-render (or even after the render finishes but before you close that window - then hit 'resume') - things like tone-mapping options, progressive render options (max iterations etc) and the filtering options (turn bloom up and down / noise reduction filter, etc)
    Cool, will have to check that option out. thanks
  • jd641jd641 Posts: 463
    Really? D:
    Well that's good news. Next time I won't cancel it after seeing it seemingly start over and I'll give it a chance to try and get back to where it was. It's just strange that sometimes the image will stay at the current iteration and sometimes it doesn't.
