Default Background Color stuck on bright white.
I know this is a small thing but it is drving me up a wall. Somehow, the default background color got changed from its normal gray to a glaring white. Try as I might, I can not find the setting to change them back. I went in and told it to load a file on new and at start up I made called "Normal" that has a gray backgound on it.  However, the white still sneaks in on occasion.  Also if I am using the draw dome command I have to go back into the environment tab and change it back to none, which I sometimes I forget about. (Also my grid lines went away and wont come back, but I coud live with that.) I am afraid to reset to default because I dont wat to lose all my custom settings. Does anybody knpw where the default background setting is hiding. I did search the post library here, but is thr search engine broken or something? The results had nothing to do with the subject I typed in no matter how I worded it.
  • Richard HaseltineRichard Haseltine Posts: 111,769
    Window>Style>Customise Style - the Viewport colour is the last item on the list.
  • ZuntarasZuntaras Posts: 17
    edited May 2020
    OH bless you and the work you do. LOL
    Post edited by Zuntaras on
    Thanks so much, lots of fun thiings on that menu. Reset the colors to default. I also got my gridlines back by resetting my workspace layout to default....
