Mimic and genesis
Mosk the ScribeMosk the Scribe Posts: 898
edited July 2012 in Carrara Discussion
EDIT - Read through the C8.5 Beta info and says there's an additional link for C8 Mimic Pro that's compatible with Genesis - downloading now to see how it works.
I saw in Carrara Cafe that Genesis and Mimic Pro are working together now.
Is that correct?
And if so, how do I do it?
Thanks.
Post edited by Mosk the Scribe on
  • bighbigh Posts: 8,147
    Is that correct?
    Thanks.
    you will need the DMC file for your model - mine are in DS 4 ( 32 ) bit - plugins - dzmimic files
    I don't know if Mimic Pro has them . It should .
    install M.pro - then click you model - Mimic will come up on the upper right hand side .
    click it - then just do whats in the Box that will come up .
