DS crashes using EJ Easy Pro Render Suite
ruekakaruekaka Posts: 348
Hello,
Whenever I try to use "EJ Easy Pro Render Suite" DS crashes when I close the form of the script. This happens if at least one object is in the scene. I does not crash if the scene is complete empty.
DS version is 4.12.1.117, Win64. OS is Windows 10 Pro, all updates installed. I installed the script manually (without DIM). I didn't work with 4.12.0.86 Win64 neither. (On an old PC (Win 7, DS 4.10) the script works)
Does anybody else experienced the same problem and if yes has a fix/workaround for this?
Any hint is welcome.
  • ScallywagScallywag Posts: 30
    Hi, I just tried it with 4.12.0.086 Win64 on Windows 7 and it worked fine. I have not used it before so I did not do much other than turning things on and off moving the figure (G3F) around.
    No crashes thought!
  • V3DigitimesV3Digitimes Posts: 3,497
    EJ opened a thread in the commercial section of the forum, you can either ask them here, or you make a ticket at Daz. But since it works for many people there should be a solution for you too.
