Wonder and Curiosity Poses and Expressions for Genesis 8 [Commercial - Released!]
SBibbSBibb Posts: 601
Hello, everybody!
I'm excited to announce that my first pose set has been released: SBibb Wonder and Curiosity Poses and Expressions for Genesis 8!
https://www.daz3d.com/sbibb-wonder-and-curiosity-poses-and-expressions-for-genesis-8
I was aiming for a sense of wonder, joy, and curiosity. There are 15 poses, each with mirrors and set to work for both Genesis 8 male and female. :-)
There are also 15 expressions for both male and female figures. They have presets (which include eye adjustments in case you want to match them to their original pose, but there's also a “Zero Eye” option in case you want to start from scratch).
Expressions also have dials, so you can easily mix and match differing degrees of expressions. For the dials I included a little icon with them to help see which expression you're dialing.
Presets include TIP files so you can hover over the thumbnail and see it better.
Other helpful side notes:
* Some poses will ask about turning limits off. Please select “Leave limits on.”
* Dialable expressions can be found in the Parameters tab under:
Genesis 8 Female > Pose Controls > Head > Expressions > SBibb – Wonder and Curiosity
Genesis 8 Male > Pose Controls > Head > Expressions > SBibb – Wonder and Curiosity
  • I've found that some of the poses will cause the figure to rotate at odd or wide angles. A quick, easy fix for this is to put the figure into a group, and then rotate the group for ease of moving the figure into the desired position. (The same method can be used if you wish to change the pose while keeping the figure from jumping back to the original starting position.)
Enjoy! I hope you find these useful for your wonder-filled renders. :-D
(Side note... if you want to know which products were used in a particular promo image, let me know and I should be able to pull up the scene file to check.)
769 x 1000 - 600K
769 x 1000 - 532K
769 x 1000 - 657K
1000 x 769 - 712K
1000 x 769 - 574K
1000 x 769 - 302K
1000 x 769 - 310K
1000 x 769 - 306K
1000 x 769 - 562K
1000 x 769 - 556K
1000 x 769 - 565K
Post edited by SBibb on
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    Looks great.  Picked it up, thanks :)
  • SBibbSBibb Posts: 601
    Thank you! I hope you enjoy the poses and expressions. :-D
  • jedijuddjedijudd Posts: 606
    They look great, not sure what I will use them for yet but I probably will still end up buying them
    Thanks! I hope you can find a good use for them if you do buy them. :-D
