Downgrade Studio 4.6 to previous version?
hacsarthacsart Posts: 2,037
Upgraded to 4.6.2.120. - and its really not doing well at all. all my issues (mouse losing focus, parameter sensitivity, etc) are now worse than ever. Is there a way to download the installer for the previous version?
sigh..
  • JaderailJaderail Posts: 0
    You will need to Submit a Ticket and request the files needed be returned to your Account. That of course is up to DAZ 3D if they will do so or not.
  • hacsarthacsart Posts: 2,037
    Thanks Mate..
    I suppose I could simply install the last version I do have an installer for 4.6.0.18 in a non-standard folder, and simply point it at my content? That might be easier..
    That will not work. Only one version of DAZ Studio can be installed per time Except for a Beta. So you can not have a Full DS4.6.2.118 and a Full DS4.6.2.120 both on your system, they both use the same Registry keys. Also the DS4.6.2.120 Plugin updates will not run in the DS4.6.2.118 version. You will need the DS4.6.2 and all the Support files for that version not just the main install file.
    Thanks mate..
    I suppose I'll have to live with it.. its just so frustrating that a product than can deliver really good results just keeps throwing so many curveballs my way..
    As it is not seen by all users, that I know of, and you have not sent a Support Ticket to DAZ 3D explaining the error, that I know of, there is no way to address the issue beyond your Graphic Card and its drivers for OpenGL and or the pointer device your using and its drivers. If you and others with this same issue Report it to Support through a Ticket giving as much information in the Ticket as possible then DAZ 3D may be able to reproduce the error on there Systems and correct it at some point in a future build if they decide it is a error that needs addressed for a general release Build of DAZ Studio. If the issue is not reported and not reproduce-able the coders at DAZ 3D have no way to track down the error.
    For Support Tickets supply as much System information as possible and a full description for the Error as seen on your PC. This is as far as I know the only way to have DAZ Studio software issues addressed.
    Consider it done..
    I suspect that it is indeed an Opengl glitch...Have tried six or seven different mice (and a tablet) all to no avail..
    Workaround? go really slow on any movement with eiterh cameras or parameters,and CTRL-Z as needed..
    Cheers!
    a thought - is there a specific OpenGL version that Studio 4.6 is designed for? That may be part of the problem..
    Here is the link to the Recommended system spec's for the current version...
    http://www.daz3d.com/products/daz-studio/daz-studio-tech-specs
    I hope this helps....
    Big help.. meet all specs, but will dig into the AMD OpenGL support. I suspect that may be an issue, will see if I can borrow a non-AMD video card to test..
    Thanks!
