BVH Export Offset (Bug?!)
lucky101manlucky101man Posts: 0
edited April 2014 in Daz Studio Discussion
Hi,
Something strange happens to G2F when exported to a BVH file.
The offset for the end sites of lPinky3, rPinky3, lSmallToe4, rSmallToe4, rPectoral, lPectoral and I suspect some of the end sites of child joints of the head are all elongated.
Below is an example of lPinky 1: note the offset of the end site for lPinky 3 is -10... -18... 15...
Below the lPinky1 example is lCarpal2, the end site for this looks/works good, and I would expect the offset of lPinky3 end site to be somewhat similar to it's values of 1.6.. -0.6... -0.42...
JOINT lPinky1
OFFSET 5.369705 -0.939590 0.793878
CHANNELS 3 Zrotation Xrotation Yrotation
JOINT lPinky2
OFFSET 2.578865 -0.191803 0.703460
JOINT lPinky3
OFFSET 1.459129 -0.407410 0.556461
End Site
OFFSET -10.125510 -18.454788 15.234108
JOINT lCarpal2
OFFSET 2.529175 0.185089 0.027870
JOINT lRing1
OFFSET 5.344772 0.152603 2.680081
JOINT lRing2
OFFSET 3.251144 -0.118896 1.168050
JOINT lRing3
OFFSET 1.829544 -0.364502 0.795549
End Site
OFFSET 1.636780 -0.613297 -0.429362
It's not the worst problem in the world, but does anyone know what the correct values of the offset should be, or could you tell me if I'm doing something wrong.
It looks like a bug to me because it's only happening on the end sites that return to their parents in the hierarchy. I would attach a bvh as an example but the forum doesn't allow it. However, I suspect it isn't just on my computer that this happens.
[Edit] I've also tried exporting G2F zero pose with the 'second life compatibility option' selected and it gives the same offsets. If there is another way of finding the correct values I could enter them manually.
Post edited by lucky101man on
  • Richard HaseltineRichard Haseltine Posts: 111,996
    Moved to DAZ Studio Discussion, Developer Discussion is for scripting.
