Altering DAZ Studio object origin/center
I somehow modified my character to the point where her center-point is off by a couple feet (see image). I see no obvious way of adjusting an object's origin in Daz. Any help?
Thanks!
363 x 277 - 25K
  • Cayman StudiosCayman Studios Posts: 1,145
    You can use the Joint Editor tool (Tools > Joint Editor) to move the Centre point (the green axes).
  • Richard HaseltineRichard Haseltine Posts: 111,996
    That's because you have moved the figure from the hip, which is generally best, but you have the whole figure selected and therefore are seeing the unmoved root node. If you select the hip you should get the widget in the centre of the figure - will that let you do what you want?
